V belt to Serp system
321GO
17
32
I want to convert a 85 v belt system I want to convert it to a Serp system from a 90 z28 that I got from the junk yard what all do I need to get this to work the 85 is a sbc with a mechanical fuel pump will the fuel line get in the way An how would I wire the alternator
You need to get a new water pump and you need a new fan. The water pump on a serpentine system spins in the opposite direction. For the alternator there is an adapter that Napa sells. There is two types, it depends if you have a gauge or a light. There is a search box on the top right of this page and there is plenty of information in this forum about wiring up the alternator
Reactions: Kratos
I have the old 70s style alternator plug with the two wires will the fuel line from the mechanical pump fit around the brackets?
another great resource for this would be kwik performance serpentine system. Check out their website!
