It's detonating, pinging, spark knocking or whatever you want to call it. Limit your vacuum advance 4-5 degrees and I bet it's gone.
Valve float it is not.
Only one way to tell other then driving the car is to pull the valve cover and take a look at the valve tip if the contact mark is across the tip it’s not floating the valve if it looks like a star it’s floating valves the valve will spin or turn when floating
These are all good suggestions that I will look at when I am able. Glad to know it isn’t valve float. The other things are much easier to cure! Thanks, all!It's detonating, pinging, spark knocking or whatever you want to call it. Limit your vacuum advance 4-5 degrees and I bet it's gone.
