Vinyl Tops Suck
9,830
13,283
I see this all too often where an otherwise clean Gbody has a vinyl top that basically ruins the car and unlike this one there aren't always telltale signs.
I hate to see what is really under this vinyl top.
Could make for a nice convertible.
The most inherent problem child in the G-body lineup is the vinyl top roof on these things. No matter how meticulous you are with it, unless you keep it in a de-humidified room all its life, it will likely rust to some degree under the top. From what I've seen, they used some sort of padding under the top, which collects and distributes water across the non-painted surfaces of the metal underneath. And it just sits in a water bath. Caught in a rain storm, or just normal washing the car will do it. If you're lucky, you won't get too much other than surface rust. If you're not, you'll have pieces of top come off in your hand when removing the vinyl.
They look great and formal and all when new. Nice appearance feature in general as it adds some classy aura to the car. But it's a cancer death-wish for the car. They never ever considered anyone keeping their cars for more than 10 years when they built them, so longevity wasn't built-in to their plans. Unfortunately, vinyl tops are almost a guarantee of some degree of rust issue underneath. Just expect the worse, and be glad if it's just surface pits when the time comes.
Totally agree vinyl tops suck ,just a big sponge on the roof
I searched for a hardtop model when I went car shopping
They have much cleaner lines ,in my opinion anyway
Reactions: 565bbchevy
I've always avoided vinyl top cars. Even in the southwest, the vinyl traps additional water, and fine sand in the lower rear window channel. Am speaking of 69-72 Chevelle bodies here. Add the fact the rear window lower channel doesn't drain, like a similar year Nova, and it is a recipe for rust and then rot. Back in the day, when living in New England, used to pop off the rear window trim periodically, and vacuum out the channel. A bit OCD might say.
I find the full vinyl top cars don't seem to have the "sponge" padding underneath.
If kept up and not cracked they don't seem to suffer as bad from top rot as the landau top cars do.
If allowed to crack and seep water under, all bets are off.
If you see the "zits" bubbling up underneath, its too late.
