Yep everything comes alive. Ran +12v to green at the switchOr the fuse.
ELCAM thanks for all the help. Does this indicate my switch is bad - incompleting the dash circuit - incompleting the L wire on alternator ???Jump +12V to the green wire and see if the gray wire at the insterment panel connector goes hot.
Ok thanks again. How do i remove the headlight switch knob??Pretty much all it can be is a bad headlight switch unless the terminal is corroded real bad or connector is damaged.
On the alternator try, with a pick bend the terminals on the connector out so they have more spring tension, gentle does it. Also clean the terminals.
Otherwise look for breaks in the printed circuit. Make sure the bulb socket contacts are not bent or corroded. clean the printed circuit contacts with a pencil eraser always pulling to the free (loose) end do not go back and forth.
Remember that printed circuit was fragile when it was new, 40 years later it is extremely fragile.
Ok so I picked up a headlight switch in town. I now have dash illumination but still no idiot lights. I started car and alternator is not charging. I still do not have +12v on L wire (at alternator) with key on …Or the fuse.
Okay I jumped 5 to 14 and started car. Gauge jumps to 14 instantly. Whats next?According to your picture jump 5 to 14.
