Not sure what you mean by major power. 400hp easy just the right hyd. roller cam and a fresh set of rods mains and cam bearings and a cylinder hone and new rings. 425-450 a different roller cam and some head porting (just clean up a little on the intake and open up the exhaust the best you can. 450-500 then a stroker kit is for you with the last cam and the 3.75 stroke with the stock bore you have 377 inches and a lot of tq to play with. I have them running from low 13 to high 11s depending on the motor and trans and gearing. You will need some good DR if your doing it right. If you can get a good runner for a little $$$ cash then the stock rebuild kit using stock pistons should be under $150 and a new hyd roller cam for under $250. Standard bore stroker kits off ebay start around $800 for the eagle kits and are complete. You just need to clearance the block and have the heads done up for the GOOD valve springs. This if you are doing most of the work your self.
