Vote Please!!!
Keep it Original or Fulfill a Dream
  • Leave it Stock
    Votes: 12 27.9%
  • Or be 16 Again
    Votes: 31 72.1%
  • Total voters
I have been buying parts for the swap since I bought the car. I bought the brand new L31 months ago. I picked the Vortec 350 because we have done these swaps before at the shop and they work awesome. With the factory hydraulic roller cam (that I’m leaving stock!) they have gobbs of low end torque and that is what I am really after.
I’m ready to start the swap but I tend to over think and worry about doing the right thing. That’s why I’m looking for everyone’s opinion.
Thanks and keep it coming. I haven’t started yet. 🤔
It's your car - do what you want with it that makes you happy. I'm older than you and the need for speed on the street or looky what I have has faded (track for that) I Know your not concerned about $$ but I don't think you will hurt the value of car but probably enhance it. Then there is always the fact that you can save everything and return the car to it's present state if desired. No vote from me, let us know what you do.
Reactions: Clarmo
Thanks for your thoughts. I am thinking like you too. If I don’t “modify” it to the point of no return, I could always put her back to original. I was actually thinking of putting the old 229V6 on an engine stand, strip, paint and detailing it, making it look brand new again for such an event.
As for the need for speed...all I’d like is the torque to roll around a corner in second gear and not getting passed by a lawn tractor. Or passing a car doing 45mph without needing a 1/4 mile running start.
The three speed gear ratios are spread apart lots (1st is 3.50:1, 2nd is 1.89:1, 3rd 1:1) so gearing down to second at highway speeds, the little v6 is outta breath.
And the “Looky what I have” isn’t my goal here either. I just want to drive this old 4 door everywhere and have a blast doin it!
Thanks again
I like the thought of either going with the 4.3 V-6 or a mild smallblock V-8. Otherwise keeping it stock in appearance. With the right upgrades, it would make a great highway car.
The challenge is to do it without breaking the bank.
My first G-body was a 79 Malibu with the base 200 V6, 3 speed and a posi rear. I had the same dream as you, even bought the small block but it never happened. Had a buddy with a '78 4door, 305, 4 speed, that car was a ton of fun.
Do it! SBC, keep the stick, and drive it.
May have to upgrade front springs, but I wouldn't change much else.....
Steve, the Iraqi cars did get a heavier A/C system. They installed the "long" style GM Fridgidaire A/C compressor on them, as opposed to the usual R4 type compressor that most A/G body cars got, and I think they may have had a higher refrigerant capacity. I've had 3 of these cars over the years. The first one was a daily driver for me, and I understand what Jamie is saying about cool, but underpowered. I got the A/C system on that first car charged up, and that car was like a meat locker inside. The A/C worked really well. As for the cooling system, I'm not sure if it was any bigger than the standard V6 setup. The rad was narrower, and it had a deeper fan shroud (because the V6 is shorter).
Jamie, as I mentioned, I've had 3 of these cars over the years. The first one was a daily for me for a couple of years in the early '90s. Not very inspiring performance, but very reliable. The second one I picked up as a parts car in the late '90s, and the 3rd, I had from about 2010, until a couple of years ago. I was going to build it up with a mild 4.3 V6, but then I found the 1980 V8/4 speed coupe that I have now, so I sold it, and 4.3 stuff as well.
Its your Iraqi car, so you can do whatever you want with it. As you've pointed out, it doesn't need to be really fast, since you've already got that covered. I kind of like the idea of a small block in it, and the EFI would definitely improve driveability/performance/fuel economy. You could go to a Saginaw 4 speed, with the correct shifter, since that's what GM did on the factory 4 speed cars, and just use the 3 speed shifter knob for the sleeper look. The shifter location is the same on both 3 and 4 speed cars. I'd actually like to put a Tremec 5 speed in my car. I'd like to find out if the Tremec shifter location would allow for the lever to come out of the floor in the original location.
Build it how you like it, but save the original parts.
I'd say what ever you do try to keep it reversible so if you want to go back original you won't be smacking yourself with a brick asking "why did I do that?" It is nice to see one in great shape as all I have seen were beat to hell, blown up, shot up, & used as a donkey cart. Even going with a 4.3 a stock one would have more power than the 229 ever could make.
I say do what you want and screw anyone's opinions. That said here is mine lol: stock cars are boring and they don't interest me even a little bit. Do something fun and crazy that stands out from the crowd. Make a head turner.
Reactions: Clarmo
I agree save the original stuff just in case. From there I would just go with a mild (stockish) SB like you planned on but I would set the 3 speed aside and put in a 4 speed. It will make it much more fun to drive and more drivable since the gear spread won't be so wide. A saginaw and probably even a muncie wouldn't require hacking up the floor and still look factory stock. Just my 2 cents.
Reactions: Longroof79
I would say do the swap, my whole point of building my Regal is to have a nice cruiser with ac and overdrive and get decent mileage (kind of opposite of my Monte) so I am going with a mild 355 SBC and later adding EFI and even though I will have a spare 565 BBC if I wanted the extra power I am trying to keep it budget minded without the need for a bunch of upgrades to support an engine like that.
