Re: My `83 Malibu
Kansas Bu Wagon, Longroof79,
It's an LT-1/T56 combo out of a `95 Z28. The fuel system started with a new wagon tank I had modified for an in-tank pump. Fuel lines are braided connected with AN fittings throughout. I must confess I farmed out a lot of the work. I got as far as getting the engine and trans in the car, then stalled out. The car sat for years. I was just about to sell it or give it away when I got a small inheritance and found a local shop to complete the swap and do some other upgrades. One cool thing the shop did was use a stock 95 Z28 radiator.
I've upgraded the suspension with stiffer springs and sway bars. I replaced the stock rear end with a Ford 9-inch with 3.50 gears (I tried to figure out what ratio would give me the best driving experience. I think 3.70 would be better. 6th gear is not of much use now.) The dash pod is something the shop found. I picked the gauges. There's probably a lot of stuff on the car I've forgotten.
I'm currently working on the tilt steering column. I've almost got it apart so I can tighten the tilt. I hope I can get it back together. One part fell out while I was taking it apart and I'm not sure how to put it back together.
