patmckinneyracing said:
From what research I've done that's what I can conclude. What's your idea? Besides the factor of age. From what observations I've made, rust seems to be a lot worse on g bodies and other vehicles from the mid 70's to late 80's. If I'm wrong than give me your opinion on why they do.
Research?
You need more experience around old cars evidently, not to mention you southern folks get spoiled...
You're lucky I've got a lot of time on my hands... :lol: There's a lot more too it than just 'cheap metal'.
There's plenty of factors that go into it... Environment, use, poor quality paint, build materials, and here's a big one... Cost cutting!
The '70s and '80s were a dark time for the General, as well as the rest of the big three.
Safety and emissions regulations were the biggest two. Both dropped right in their laps in the early '70s, these were such monumental tasks they stole a lot of the attention as the automakers tried to meet all the stacking requirements.
Unions were becoming greedy, workers were frequently on strike, moral was low, and build quality suffered.
For instance, your all new '71 Roadrunner was supposed to be introduced as a '70 model, intented to be released alongside the all new E-body.
Plant strikes prevented that, and the car that turned out to be the '70
B-body wasn't even supposed to exist, and the redesigned
B-body was pushed back to the next model year.
GM workers on strike in the late '70s left thousands of unpainted truck cabs and body panels outside to rust, panels that were simply painted over when production resumed, resulting in thousands of trucks needing to be repainted under recall.
75 year old factories were deteriorating. One winter the roof collapsed at one building under the weight of the snow, damaging dozens of new Oldsmobiles waiting to be shipped. The cars that weren't destroyed received vinyl tops to hide the repairs.
Back to G-bodies.
Sure, there's a quick smear around the door and trunk skins, but do you see any seam sealer
underneath your G-body? How about undercoating other than the rear wheel wells? Of course not! That would've cost a few dollars per car!
Multiply that by the million-plus G-bodies produced each year, let alone other platforms, and that's a lot of money for an already struggling GM to save.
I'm sure the pencil pusher that figured that out got a huge bonus...
G-bodies rot just as bad as any other old car for the exact same reasons... because there are plenty of nooks and crannys for debris to get trapped, get wet, stay wet, and then corrode. Various body styles and platforms all have different spots that are notorious for it.
Cars get driven. And when cars move, they flex. As time goes by, things flex more and more, and materials become old, brittle, dried out, less flexible. Maybe just enough to make a small split in some sealer. Maybe just enough to crack a little bit of paint. But in reality, that's really all it takes, because once it starts, nature takes over.
Lets talk paint.
G-bodies, as well as all other cars of the era, were all painted with laquer paint which, fades, oxidizes, and breaks down over time.
The most common condition is laquer-checking or "crows feet". The layer of paint basically splits, allowing the environment to attack what lies beneath.
Sure, there are well maintained, garaged examples that still look ok, but most of them don't.
My all original Buick wagon was garaged it's whole life prior to me buying it, and it's paint is worn through in several spots, and checking in several others.
How about building materials? Aluminum was huge in the G-body era, helping shed pounds to help meet new strict EPA regulations.
But when placed next to a dissimilar metal, like steel, it creates something called galvanic corrosion. It's why G-body rear bumpers often fall off, due to the aluminum inner-reinforcement, or even just aluminum shims between the steel bumper shock and a steel reinforcement. How about those anodized aluminum wheel well moldings? Sand and other debris work their way in between them and the body, and before you know it, both the fender and the trim are rotten.
Remember my Malibu wagon?
Rear frame rails, rocker panels, door bottoms, all gone.
All provided excellent places for road debris such as dirt, sand, and especially snow, ice and salt to get trapped.
All those areas were pretty much gone on my car, yet my non-undercoated floors were perfect. Exposed to 30 years and 225,000 miles of Iowa and Minnesota winters, dirt roads, and everything else inbetween.
Must be some junk metal...
