Want to swap th400....
I would be more worried that it takes about 35 more horsepower to turn a Turbo 400 than a TH350 or 200 metric. That 307 doesn't have a ton of power to spare to be just donating it to drivetrain losses.
Reactions: JAMCAR223 and TURNA
I haven't seen any concrete numbers on HP but this is what they say they take -
PG 15-18 HP
350 35-36 HP
400 44-45 HP
If I could swap out my 400 for a 350 and gain 35 HP it would have been done a long time ago - It will get a PG in the near future.
400 is a good trans but a gas hog. A 200 can be built to be awesome. Buy once cry once
PG 15-18 HP
350 35-36 HP
400 44-45 HP
35hp may have been a bit optimistic, but I was going from memory. I do remember that the TH 200 was pretty close to the Powerglide in weight and rotating mass. It obviously needs to be modified to handle much power though.
Which is why, if you can eat the cost and find a good builder, the 2004R is the best of both worlds. A better first gear, the same as his 200 and the .68 OD allows decent gearing added. There are a lot of BOP TH400 cores out there, unless he is planning big power, why? As said, the TH250/350 regular or C was the direct swap done many times in place of the weak and troublesome TH200.
Reactions: fleming442
