Warped SBC intake manifold
Clone TIE Pilot
3,861
2,612
Galaxy far far away
I have been having issues with a nasty yet hard to find vacuum leak. Finally found that the intake manifold gaskets on both banks were leaking. Especially around the ports for cylinders 6 and 8. Removed the intake and put a straight edge and feeler gauge to it. Passenger side is flat but the driver side has .015 warpage at the ports for cylinders 6 and 8. The engine is a HO 305 and a used GM ZZ4 intake manifold. Can it be saved with milling or do I need a new intake manifold?
bracketchev1221
1,415
1,654
If its off take it to a machine shop and get an estimate. Like was said, between setup and milling time, a used $75 manifold may be cheaper.
5,710
12,220
Any chance the heads or block have been decked poorly?
12,177
9,779
I think I would also try the thicker intake gaskets. What do have to lose? Worse comes to worse, it doesn't rectify the problem and you pick up a cheap Performer intake.
303'505rollin
700
587
Colorado2newmexico
Give it a light spray of gasket stick it looks purple or a paint and block the gasket surface with a fine grit and see if its flat. If its really close maybe do it yourself or take it to a shop and get it shaved flat but then is it the same price as a newer one
CopperNick
3,357
3,018
Canada
Thicker gaskets with a coat of Perma-Tex High Heat spray a gasket added to them for insurance.
Check out a couple of upcoming swap meets in your area and see what's around. E-Bay but be aware that they are a Buyer beware situation.
If considering the self-machining route, Might be possible to do it with a rigid sanding block like body-men use to block sand panels. Use 400 or finer Wet/Dry paper or emery cloth and wet it with machinists tapping or cutting fluid. I have seen a block decked that way but it was more of a cleanup of the head gasket surface rather than an exercise to remove material. Would say this is a last resort option.
If the manifold has some history with you then the machine shop. Question? Does your local college have a machinist's training course and do they accept walk in customers with work to be done that a senior student could do?? Know anyone who happens to have a milling machine and would trade work for booz, work, parts, ???
Clone TIE Pilot
3,861
2,612
Galaxy far far away
I bought this ZZ4 manifold used off of Ebay years ago for $20. Sadly intake manifolds with EGR cost a good deall more than ones without EGR. I don't know anyone with a mill.
I still have the stock L69 intake sitting in the barn. Just checked it out and it is not warped. However, its pretty dirty and is badly eroded around the rear coolant ports. Probably requires welding and milling those ports.
