It's kind of a process of elimination. First, I would check the drain at the bottom of the heater/ airbox by unscrewing the screen, and using a garden hose and maybe a coat hanger, welding rod, etc. Next check for leaks around the airbox itself.
Also check around the windshield for rust holes, under the stainless lower windshield trim, and also body seams.
You could use a garden hose on a good day with the help of an assistant. Have them shoot the hose on different areas while you observe in the car with a flashlight.
Just a few things I can suggest. Good luck!
