Ahhhhhhhh, I wondered... So the original is correct then ?Not exactly the same.
Threaded bosses for V belt brackets.
No bosses on the serpentine one.
If it wasn't seriously overheating I would say you are good to go with the old pump,Ahhhhhhhh, I wondered... So the original is correct then ?
Keep in mind when you are buying parts your car has been modified.
When searching for anything on the front driven by the belt you need to search for something else like maybe an 89 Camaro with a 305. Not sure what car, we can only guess since someone else installed that stuff.
water pump
fan clutch
fan
alternator
power steering pump
ac compressor
pulleys and brackets
Those will all come from car X which will be a later chevy.
If I recall the carburetor and distributor are also not stock and will come from car Y an earlier non CCC chevy.
This is normal for old modified cars I have much worse with a chevy with an olds engine, cadilliac transmission, ford rear axle, blazer spindles, camaro brakes. on and on.
Not sure completely, never overheated (smoked or died) on me though.If it wasn't seriously overheating I would say you are good to go with the old pump,
I've stated it plenty times... I'M HERE LEARNING !!! PLENTY OF OTHERS ARE !!!There’s no way this can be real.
You’ve been told numerous times that you’re engine has been modified. The engine might be an 84, but is using an updated accessory drive. All you do is yell back at the people that try and help you. You were told way back in the timing chain thread. So then what do you do, you ordered a water pump for an 84. Then when someone said it’s wrong you show that it fits an 84. You should do what I did when I was learning. I shut up and listened to people that tried to help me. It’s your car. I honestly couldn’t care less if you put the wrong water pump on the car and blew up your engine.I've stated it plenty times... I'M HERE LEARNING !!! PLENTY OF OTHERS ARE !!!
At some point in life you did too and asked the same damn questions. Nobody here was born with the knowledge they have now.
Grow the **** up, unfollow my threads, and quit sabotaging my threads with toxic and negative comments, so others will chime in to do the same, turning this thread longer than it should be...
I've asked that multiple times in other threads that you and others have acted in...at this point, its harassment...you all are following my threads just to talk sh*t to, degrade, and disrupt someone trying to learn... Like the class clowns you are...
Get a ****ing life...you and the rest of them who do the same...
Never seen nothing like it...smgdh...sick of this bullshit...
