I finished installing new t-top and door seals today and I’m not pleased at all with how it turned out. The t-tops fit really tight, which I expected as I know the seals will need to conform some, but it seems too tight to me. Also I had to mess around a lot to get get the front part of the seal to not come up above the roof line, hoping the adhesive holds them in place so it’s flush. Also, when I put the tops back in there is a gap between the strip on the pillers and the top seal. On the doors, they won‘t shut all unless you slam the hell out of them. The seals at the front of the doors and a pillar are smashing together. I can’t see where they can be adjusted any, the pins are in the correct locations. I used Metro Molded Supersoft seals. Seems like a pretty straight forward process, did I install them wrong?? Just not a good brand of seals? Here are some pics.
