1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Weird rattle sound like something stuck in the fan???
Discussion in 'Engine / Swaps etc.' started by 84hurst, Jul 1, 2010.
Thread Status:
  1. 84hurst
    84hurst Apprentice
    Aug 17, 2008
    94
    Lansing
    Allright im gonna try to describe this the best i can. i have a stock 84 H/O with the 307 of course, I get this weird noise kind of like a sound when something's stuck in a fan and kind of flaping back and fourth, Its always there when you start it cold, but then if you get on it when its warmed up it goes away. WTF??? It still does it in park so i can eliminate anything from the trans back. It gets louder as the engine rpm's rise, its not the smog pump as the barrings went bad so i cut the belt. The fan shroud is as clean as can be. So im lost as to what else could be spinning and making this noise? Anybody have any ideas or heard this???
  2. othtim
    othtim Master Mechanic
    Mar 23, 2010
    395
    16
    I know this is an old thread. But all of a sudden, my car is making a sound that is very similar. I was actually searching through old posts looking for some help, but I stumbled across this thread which already accurately describes the issue I am having. Sounds like the fan is doing strange things, but it appears to be fine. Help? :S
  3. 83hurst-olds
    83hurst-olds G-Body Guru
    Oct 19, 2010
    514
    near Oklahoma City, OK
    Clutch fan maybe?
  4. pontiacgp
    pontiacgp Rocket Powered Basset Hound
    Mar 31, 2006
    18,069
    1,100
    Kitchener, Ontario
    fan blades loose?
  5. Bonegrater
    Bonegrater Not-quite-so-new-guy
    Nov 21, 2010
    45
    Richmond, VA
    My car started doing this, and it is the fan hitting the top of the shroud. I don't know why, but it stops after the engine runs for a few minutes. Could this be worn out body bushings allowing the shroud to be low enough to just tick the fan blades? Does anyone know why this would happen? I would like to get it fixed as soon as possible.
  6. RockSS
    RockSS Master Mechanic
    Oct 24, 2010
    276
    Enfield Ct
    It could be the clutch fan wornout I had a similar prob on my elky ... when the car is OFF i repeat OFFjust grab a hold of fan and try to wiggle it if it moves time to replace and yes other things can fatige...
  7. Peter
    Peter Royal Smart Person
    Jun 27, 2007
    1,171
    5
    38
    MA
    waterpump bearing a possibility
  8. G-Body_Vet
    G-Body_Vet Comic Book Super Hero
    Oct 15, 2010
    3,023
    44
    48
    X2. Check for top to bottom and side to side play. Does it also sound like the rpm's are higher or like the engine is dragging? Those fan clutches do go bad. I've never seen one so worn that it would result in nicking the fan shroud though! It should spin freely too. If it doesn't you've managed to turn it into a factory flex fan.
  9. bill
    bill Comic Book Super Hero
    Jul 11, 2008
    2,648
    38
    southside va/lake gaston
    These clutches are fill w/fluid or are spring actuated. They should turn, but with resistance (depending on how cold the air temp, the easier it will spin). A free spinning fan clutch at normal operating temps usually indicates a lack of fluid in the housing or in other cases, the spring inside is broken or weak.
  10. Bonegrater
    Nov 21, 2010
    45
    Richmond, VA
    Sorry it took a while to reply, the fan has no movement at all. None front to back and none side to side. I noticed it had stopped doing it for the last week or so. Then a friend from work rode with me to lunch, and he weighs around 290-300lbs. After he plopped in my seat I fired the car up and it started up again. After he got out it stopped, any ideas?
Loading...
Thread Status:
Share This Page
