keep your materials as clean and as close as possible whether you're adding filler or just fusing together.a little run on time(pre&post)gas might help keep the puddle a little bit cleaner as will trimming the end your filler after each weld.knipex makes an awesome pair of hand bolt cutters that work very well(cuts tungsten no problem)but a new pair of cutters from harbor freight work good on most rods too.
you don't need a wireless pedal,the wired one's work excellent..it doesn't matter how much weld p*rn you look @ Instagram practice will prevail..worry about welding a dick on a snowman later..
