Welding - What to Unplug
If you unlpug the ECM, MSD, whatever, then you can be assured that it won't be damaged. Is it really that difficult that you would not consider unplugging it? If you get done welding to find out that you fried you MSD box, then you might consider if it was the worth the amount of ease that was created by not unplugging it.
I unplug the ECU(s) everytime I weld on anything (shrug).
Basic rule of thumb is disconnect negative battery cable, however I have welded on many cars as new as 2019 with as many as 38+ computers never disconnecting a thing everything was fine. At the end of the day it’s how much time you want to spend to take precautions.
Reactions: pontiacgp
There was a bulletin in the early/mid 2000s from Ford about the instrument clusters in the E-vans. Seems they were especially susceptible to damage from welding near them, They stressed that not taking the proper precautions would damage the cluster and it WOULD NOT be a warrantable item.
Reactions: dr78442
Old Neon PCM. Died randomly on hot days. Started a couple weeks after a rear body and taillight pockets were welded in.
