Well pump issues...
Thanks for the update. It’s good to get this feedback after all the armchair diagnoses fly around. Glad to hear that you seem to be on your way to closure.
I always hate threads where lots of suggestions or troubleshooting go in and yet you never hear the outcome. Although things get busy at times I always try to get back to it... eventually.
Besides, it's always interesting to know who guessed right, even if sometimes the same issue could have different solutions.
Good to hear you got things sorted out. Mostly, anyway.
It's on the way at least.
The stop start/stuttering of the pump could have churned up mud around the suction pipe and guess where the debris goes?
Do you have a trash filter in the suction line to the pump, or whole house filters going into the home? If not, you should consider them. If you're getting mud out the faucets, you're getting mud in the toilet water tanks too, along with the water heater, etc. That could wreak havoc on those in-tank toilet valves as well.
Have you considered being a prophet? People sacrifice nos olds parts to you for some wisdom?
This house was supposed to be several things... but what's its become is an effort to get it back up to par.
A toilet just got replaced because the intank valves went fubar, and, coincidentally, both the upper tank bolts oxidized beyond any separation without porcelain damage, the wax ring was bad, and an upgrade cost $68 for a complete kit - tank, bowl, mechanicals, ring, seat, etc. Cheaper to replace with better than repair heavily corroded parts.
So we've been blowing clear various lines, changing various filters. It doesn't have one of those whole home filters of the type you suggest, although that would be smart.
Also changed/removed were a water filter on a shower head that clogged itself, a couple branded lines, and a damaged faucet.
Most recently, the hot water faucet at the sink furthest from the water heater is putting out cold water, every other faucet working properly. So there's a cross-over issue going on, although there is no laundry equipment which is often the source. Could be a tub/shower valve, but, it's a half bath so you'd think the sink nearest it would show that issue. Never know pipe routing though.
There's still an unknown water filter system under the kitchen sink and looking into the dishwasher to consider. The rest are, for now, starting to be sorted and falling into place.
So, household water plumbing has advanced through 101, 102, 103 to course 104.
