if they're doing it cheap and making big power, they like changing engines. I like working on my car, but let's be serious. Do you really want to yank it out every 2 weeks?
Gotta put 'em on a zipper. Junior's Motown was put and pulled 3 times in one day before I smartened up enough to put oil dye in to find out the at the rear main was NOT leaking lol.
Any stock cathedral will make 550 crank on stock valves, rockers and pushrods.
The motor and trans aren't the expense. It's the electronics and fuel system IMO.
Cam and springs - $400
ECM - $1150
Fuel system - $700 but probably closer to $900 minimum
Mounts, exhaust, oil pan,etc - $100 in parts and $500 in gas and wire for the welder and figuring your time is $10-15/hr lol - $600 total
I say $3K minimum. I'm at $7k (and counting due to the destructed 'indestuctible' 4L80 lol), but hopefully I'll be at 750-850HP with turbo and related goodies.
The expense isn't the motor and trans........it's the rest. But I believe that I'd be at the same point with a 383 and TH400, but when something breaks, I wont't be able to find another 383 for $250 + cam and springs (if they can't be salvaged.)
And 100%, absof'inglutey do I expect to be swapping in the next bullet in less than 5 hours. Give me a carb'd motor with HEI and I'll cut that time by 40% lol. I used to look at pulling the motor like such a project, now I look at a door panel and window regulator in a worse light.
I should mention also that in my $7k+ is Macguyver's 8.8 swap kit
