Depends if you have a dual-bed catalytic converter, or "three-way."
With dual-bed, an air pipe runs to the converter and is needed all the time for converter operation during normal driving. The computer assumes it's there, and adjusts the mixture differently than for "three-way."
With "three-way," the smog pump is only active during warm up, then it's switched out and does nothing. There's no pipe to the converter. The converter will work fine without it, and the computer won't know the difference (but will probably complain anyway).
Either one is in the way any time you have to get at anything.
EDIT: Also, on your Buick V6 no ports on the exhaust manifolds, a tube runs to the intake manifold behind the carburetor.
