Just to have enough done to drive down for a cruise with Rktpwrd and see the Juggernaut.
Oh ya, 12.5 1/4 and do at least one autocross event.
I used the stock G-body bellhousing with an F-body T5. You need one of these:I'm going to change the bellhousing to get rid of the T5 WC tilt so I'll have to be changing the transmission crossmember. I'll have to figure out which crossmember will fit so if any of you know what fits please let me know. I also want to put on the rear disks that i mocked up years ago and change the brakes to manual.
I cut off the trans pad, cut a piece of box tube, drilled and bolted it onto the mount on the now-upright transmission. Then I welded on some Rube Goldberg angle iron. Worked for years until I got the TKO.
I picked up a Ford T5 tailhousing to see if it could work as a swap to put an upright mount under a F-body T5. The housing is shorter, the shifter is in a different location, and the output yoke is a different size. Then I wondered if I could make an angled shim - too much tilt to correct, would require mounting the pad below the crossmember. Finally, I explored machining the mount down and epoxying on a thinner shim, putting a strap around the top of the housing for security, but I did not have the resources.
I'm interested to see what solution you design.
Another th350 but one built by someone that knows what there doing. It's actually done I just need to pick it up and put it inWhat trans are you putting in it.
I was going to keep the 200c in the Cutlass as a spare but if you want it, it's yours.
Shift's and works like new.
Only one burnout ever done in car!!!!!
