one thing to watch out for when comparing HP numbers--they changed standards and methods. the 3.8 was tested at 110hp 20yrs ago true. the same engine today tests at twice that. thats why the 'vettes were only rated at something like 230hp with a big block. the real number was more like 350-400hp i think. todays rating system is much more accurate.
A big block hasn't been in a production Corvette since the mid 70's and even the 1974 454 4spd wasn't even close to 400hp, then you get into the early C4 Vette which weren't any faster than a 350 TPI Trans Am or Z28
this is why i have always thought that vettes were overpriced rolling garbage cans!
_________________
wow no love for the car that is said to be the "best bang for the buck" of exotic cars??? yea the 70s and early 80s may not have been what they maybe should have been but come on, anything from the late 80s on especialy lt1 to present vettes??? they are worth it!
Reds, STLRegal had it right. Just drive the 3.8 while you locate acquire machine gather speed parts for and have the motor you want built. It will likely depending on your budget take you several months or a year plus to accomplish that, in the mean time just drive the 3.8 sinking no money into it other than maybe a tune up. Finally if you just can't stand it locate a used 4bbl intake & carb off the Buick 4.1 as it will be cheap is a direct bolt on and will provide both better mileage & a little more power. The good thing about the 3.8 like the 307 is short of timeing chain, oil pump & carberator rebuilds you can not wear them out.
Fine... I usually mention "Turbo Regal" instead of GN. I am probably one of the few who know that the drivetrain was offered in more than just the GN and T type-it was an option on any 2 door Regal from the most stripped model to the GN and even the Regal Limited.
The 2 3.8's being the 229 Chevy and 231 Buick are both long lasting engines but they have virtually no power. They are not worth building on, and when they go a V8 swap that you can build on is the way to go. Keep in mind however that the stock V8's of the G body era were not very powerful either, with a 305 making if I remember correct 130 HP and the 350 making 150 HP. So if you are swapping in a stock engine without building the engine up, you are not going to get a dramatic increase in horsepower over the 3.8 V6. I had a '78 Cutlass with the stock VIN H 4 barrel 305, and when you think you would have big power with a 4 barrel V8, it was nearly as anemic as either of the 3.8 V6's is. These cars are lead-sleds, and to really get good power out of a small block V8 you have to drop the emissions equipment and put in a cam, carb, intake and exhaust that can get the thing moving.
