What fuel pump to run
Big, bulky, requires maintenance and a little bit noisy as well, but alot of external pumps are noisy.
Reactions: Codyccg
Ended up going with the magnafuel4303. I got these fuel filters but I'm not sure what side is the inlet side there is no directional arrows does anyone know?
Entry looks solid.
Exit is rubber seal.
Pull the filter apart and have a look.
This is how the Magnafuel filter recommended for the pump is installed. I would do it this way.
Hopefully it works for you.
When in doubt, call Magnafuel - they answer.
I'm a believer in the big filter.
This bad boy is a foot long and serviceable. It won't plug unless I fill the tank with biodiesel.
p.s. - keep us posted on your build, excited to see you make some go with this.
