I've only driven my 87 once, the drive home. Since then it's been on jackstands and I've been fixing/restoring/upgrading.
I noticed there was some coolant on the oil filter and the block (so passenger side, near the back). I cleaned it off and started the car to so where it was coming from. Appears to be coming from between the head and block, just below the rear most spark plug.
I'm thinking best case scenario, needs the head bolts to be resealed. Possibly needs a new head gasket.
Can you guys tell me which bolts need thread sealer? I'd like to try that first, before pulling the head. Is it the outside bolts, or the ones under the valve cover too?
I don't know much about the engine. Previous owner didn't know a thing about cars so when it started to need some work he got rid of it. What I do know is very generic - 383 rebuild at some point and I saw a raised "DART" casting on the iron heads.
