350 HO Tech Specs: Part #19210009
Engine type: Chevy small-block V8
Displacement (cu in): 350
Bore x stroke (in): 4.00 x 3.48
Block (P/N 10105123): Cast iron with 4-bolt main caps
Crankshaft (P/N 14088526): Nodular iron
Connecting rods (P/N 10108688): Powdered metal steel
Pistons (P/N 12514101): Cast aluminum
Camshaft type (P/N 12480033) hydraulic roller
Camshaft lift (in): .435 intake/.460 exhaust
Camshaft duration (@.050 in): 212° intake/222° exhaust
Cylinder heads (P/N 12558060): Vortec iron; 64cc chambers
Valve size (in): 1.94 intake/1.50 exhaust
Compression ratio: 9.4:1
Rocker arms Roller/ self aligning
Rocker arm ratio: 1.5:1
Water pump (P/N 88894341): Cast iron, long-style
Flexplate (P/N 14088765): 12.75"
Recommended fuel: 92 octane
Ignition timing: Base 10° BTDC, 32° Total
Maximum recommended rpm: 5500
Balanced
Reworked Q-Jet Carb.
Dual exhaust with 2 in 2 out catalytic converter and twin Flowmaster super 50 mufflers
Transmission 1992 700R4 from a
Caprice 9C1 Gill Younger valve body. Painless TCC kit.
7.5 rear end with Eaton limited slip and 3:24 Richmond gears
Nordskog digital dash
17 inch Summit legends wheels with 235/50/17 Michelin tires.
17 MPG on the highway. (less in town I can't keep my foot out of it)
