I just went back and re-read all that pamphlet again. Impressive! I saved that for future reference. The detailed explanations like those are the reason why I chose the RACOR water separating fuel filter made by Parker for my Whaler. As for the O-rings I guess the VITON and BUNA are easily available and not so expensive that I can't try both. I can try one of each type in either cylinder and test them. Being winter I can actually test under freezing conditions. I modified the hinge bolts that secure the hydraulic cylinders for easy replacement. Normally the outer bolt is impossible to get out of the way and makes extraction extremely difficult. It forces you to unbolt the entire male hinge assembly and lower it enough to get the outer bolt clear. By grinding off 1/16" from each now I can remove/replace the entire cylinder in a matter of minutes. The car is stripped so I can test and change parts easily. Funny thing, on the 1st Gen site the guys that figured out these O-rings are indeed serviceable had no idea what type to use. Some stated that ACE hardware grade was fine, one guy sourced from a hydraulic supplier, another used the HNBR AC rings. Leave it to the G-body guys to have the best information, as usual.
