Viscosity depends on climate and bearing clearances. You wouldnt want to run 20w50 in the winter with a motor that has tight bearing clearances. However 5w30 would work. What is your climate?
Edit:
I see you are in Virgina, so I am guessing your about as hot as Michigan maybe even more right now. I would say 10w30 at a minimum in hot climates. 5w30 drips like water when its engine temp.
Edit:
