If its a stock engine, Id use the M55v or the M55 oil pump. The v pump is higher volume for higher performance applications. stock cruising engines would be fine w/the M55 model....imo.78monteclassic said:Engine is not the original one it came with, casting code is 14094766, it's a 305
Ill look into that .... and thanks for the advice....I'll file it in the usual spot. Im sure the defected parts were most likely removed from the shelves from most retailers to eliminate any possible lawsuits. We get vendor recalls on hard parts on a regular basis...and I think this issue would qualify.pontiacgp said:Bill, you need to read a to keep up so you know what you're selling. Melling changed their castings and made them thinner in 2009 and 2010 and they had a problem with the casting breaking. There are still alot of them around. If you have a casting with a 5 digit part number then you have the old style before the thinner casting. Melling also had a problem with the powdered metal instead of billet steel for the gears but have gone back to the billet steel gears. Melling has also gone back to the thicker casting which are now called the M55A.
