what typ of holley carb is this
kendl77
Oct 28, 2009
56
okay i need some heelp on figurin out the model/cfm of a holley carb i had llaying around that i am trying to sell. it has a number of 7806 on the top...i am going to post attatch some pics i just really wanna know what kind it is so ill know where to set the price...thanks i really appreciate the help ahead of time..
I am too lazy to Google it for you, but I would suggest a search term of "Holley 7806". I am sure someone has posted it somewhere online. As for my best guess, I would say it is a 600 CFM emissions Holley. These were built as stock replacement carbs during the 1970's and 1980's. Typically, they were used by people who did not understand Quadrajets, or were tired of some of the more troublesome smog carb variants of the period. These would include the Motorcraft Variable venturi and 4 barrel carbs (all Motorcraft carbs were rubbish!), the Carter Thermoquad, and possibly also the Carter AVS. Applications were widely varied, but most used the 4150 (4160?) architecture like the old stand by, the List# 1850 600 CFM universal carb. Ford also used holley 4 barrel carbs in the 1980's on 302's in Mustangs, 351W police LTD's, and some 302/351W large trucks and vans. However, the Ford Holleys have a vapor recovery line on the float bowl which I do not see in the pictures you provided, so it is not one of those unless someone changed the bowls. The final possibility is that it could be a small carb intended for a tunnel ram or other dual quad configuration. These were typically either 390 or 450 CFM, and were also sometimes used on inline sixes with Clifford or Offenhauser 4 barrel intakes.
5 minutes on Google netted this:http://www.pirate4x4.com/tech/billavista/PDFs/New Jun 2003/holley numerical listings.pdf. further searching did not net the size, but it did net the fact that it was a stock replacement carb for a 1975 Pontiac. If so, it would be a spread bore carb ( secondaries larger than primaries), and not a square flange. That is all I found in the few minutes I put in to it. I would also try Ebay and use the same search terms, or combinations thereof. Someone who knows exactly what it is may be selling a similar item and list the specifics in the description.
i doubt its any bigger than a 600 becuase i had it on a 307
and it pushed it along pretty good and never flooded where as
a year ago i had a something like a 750 on a 307 and it would always
flood so i dont think its any more than a 600...it also has the holley logo imprint in the small font i know that the newer ones have more of a bold font holley imprint.
