Street Demon 625 cfm, if you want shiny new. It is a 3 barrel heavily based off the Carter Thermoquad the Carter AFB's replacement, which is the Edelbrock carb. Both carbs will be rich out of box, they are set up for 9+ to 1 350+ ci with bigger than stock cams. One guy put the Street Demon on a 8 to 1 350, got 14 mpg. After leaning it out, 19 mpg. It is very similar to Qjet, 20+ should be no problem with a properly tuned Street Demon. A stock late 70's 305 or 350 Qjet with the right linkage will be very close for your stock 305. I assume that intake is equal to the Performer RPM?
