monte olrac said:
I hear what you are saying, but you the force on rear pads is not increased, keep in mind the pressure is applied to edge of pad so you never gain surface contact with a larger bore cylinder, so you never get a increase in pressure. Unlike disk brake were your clamping force is contributed over a larger portion of the pad and rotor. But thats just a bunch of pascals laws and stuff, I know from my little experiment that there was a noticeable difference in pedal feel between the two and the stocker were much better, maybe someone else had better experiece with them. so maybe we have to agree to disagree, but you can check out this article to see what i was talking about.
http://science.howstuffworks.com/hydraulic1.htm
your wrong about there not being an increase in rear braking with the s 10 non power brake wheel cylinders...on a
Grand National they can hold the rear wheels from braking loose up to 4 pounds of boost with the stock wheel cylinders...with the s 10 cylinders the rear brakes can hold the wheels from braking loose up to 8 pounds of boost....I know a speed shop where they specialize in Grand Nationals....theories are nice to read about but the real world is the best platform to test.....
another way to increase rear braking is to use two primary shoes on each side
