Need some help on which wheel cylinders I need. My 87 Regal is an original 307/2004R car with the stock 7.5 inch 10 bolt rearend. Do I need the ones with the mounting bolts, or the retainer clips? TIA.
Where did you find these? Do you have a part#. I have to replace the cylinders on my 84 and would like to do this upgrade. Will these cause the rears to lock up to easy?retainer clip.....some upgrade the cylinder with a non power brake wheel cylinder from an S10. I would also get these brackets.
Here you go....Where did you find these? Do you have a part#. I have to replace the cylinders on my 84 and would like to do this upgrade. Will these cause the rears to lock up to easy?
