Ok so I have a 1986 Regal Limited 307 Roller motor. I am trying to figure out where these plugs are supposed to go before i cut them as i am stripping the ECM and installing non CC Carb. The big one with the blue red and light blue wire is connected to the small black negative cable on the Alternator and then it goes into the fire wall behind and under the Brake booster.
The plug with the black and green wire is on the passenger side and was just hanging near the headers. It runs down towards the distributor and enters into a "T" shaped wire terminal. It is melted and ruined but i want to make sure i can cut it off or if i should find another plug.
I have spent the better half of 6 hours probing forums and google images trying to figure out where those two plugs are supposed to be hooked to and never found anything. Did Buick/Oldsmobile just use a generic wiring harness for everything which left certain plugs unused?
Also on the picture of the plug that is in the manifold near the Alternator with the black and yellow wire, that was connected to the ECM. Is that the temperature sensor or is that other plug next to it, what is that plug and how will it not being connected to an ECM effect me? Thanks for the help!
