Ok so I found the tps wire and I see its connected to a little clip that slides on the tps. It was unplugged and really it didnt do anything but now show me the choke and oil light on in the dashboard. Ya'll think I should keep it connected? Why they had it disconnected I dont know why anyone know? Is there a reason? Anyhow, I tried the opening the butterfly flap when the car was running and all it did was bog it down and shut the car off. So that idea is out the door. Maybe it wasn't warmed up real good I dunno but it seems pointless. I did go and buy some carb cleaner and soaked the sh*t out of the carb and worked all the joints and levers to get them freed up. Tomorrow I will drive it around and hopefully I can get it to accelerate good enough to drive with traffic. I do see that the choke moves slowly up after I have started it. So I assume its working correctly? Anyone think I should be doing any more of adjustments in the carb? It idles decent but you can hear it sort of drownding out when at WOT but not cutting off.
I checked my sparkplugs carefully today and noticed that only the driverside 3 sparkplugs are the only ones covered in oil or fuel. The passenger side 3 cylinders look fine.
