Disconnect the arm going to the choke (butterfl/flapper) if you can and lock it open with a piece of wire (you can probably do it without disconnecting if you have to). I once held one open with an alegator/ roach clip, clipped on the choke blade. you just ant to force it to stay open temporarily.
The car will probably run bad until it warms-up, since the choke is supposed to be closed until it is warmed-up, so if you can get it to warm-up first it would be best. This works alot like when you stick a screw driver in the choke to start a flooded car, but you really can't test drive with a screw driver sticking out of your carb.
Try it and let me know.
