The driveshaft is the same, but the transmission crossmember is unique to the TH 200 4R. You will need the crossmember and mount to make it fit. As for which I would choose, I would go with the TH 200 4R without hesitation. Better ratio spread and a steeper overdrive make it a no brainer. As for a torque converter, stock should be fine with the intake and heads you are running. The SP2P is not a great high RPM intake, so there is no real advantage to a high stall converter. For gears, 4.11's are just plain silly. I would not go above a 3.73 at most and preferably no higher than a 3.42. Why? Well, you have a street car with a torque engine that will be out of breath by 4,500 RPM. There is no need to run 4.11's. All you will do is waste gas and shorten the life of the drivetrain. However, if you want to get more performance out of that trans and engine, try a higher shift point governor in it. The stock WOT upshift in a pedestrian TH 200 4R is only around 3,000 RPM. The MCSS, etc. all got a 4500-5,000 RPM upshift governor instead. Add that, a good shift kit, and a trans cooler for the best results.
