Which transmission oil? Th350
Myles
Jun 17, 2011
80
17
8
Hi guys,
Curious which oil to use, drag only, 12 second car.
Th350 fresh rebuilt, rebestus clutches (silver/metal in colour)
Trans go shift kit. Will have cooler in front of rad.
Custom 4200stall 8"
Dextrose 3? Type F?
Please let me know what you think,
Thanks
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
I used to use a mix of Dexron and Type F. (non synthetic)
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
The only one on that list that will work is the Royal Purple.
BoostedJROD
Jan 9, 2019
61
90
81cutlass
4,649
13,565
Western MN
A lot of the big power turbo LS guys with 4l80e's run John Deere Hygaurd hydraulic oil. Maybe a quart of ATF with it to give some color to the fluid to check the level since it's clear and tough to see on the dipstick. Don't buy the cheap stuff though because the oils actually do have different additives in it.
It's cheap'ish' and has a good amount of additives that make it more resistant to heat over a basic ATF. Red ATF is basically just hydro oil with some detergent and red dye.
bracketchev1221
1,415
1,654
Straight Dexron or type f is fine. I ran my car into the low 9's on straight dexron fluid and never hurt it. I went to the Type F later on and can't say I ever saw a gain with it.
