The 307, is not a bad motor. Not at all. Some even had factory roller cams and lifters! VIN Y and VIN 9 I believe The can be built up a little, but it's like the Chevy 305. Decent motor in stock form, can be built to be a bit peppier, but swaps are just so much easier and cheaper in the long run. Plus, it's literally plug and play. The blocks are exactly the same on the outside as far as mounting things like motor mounts and bracketry go. If you want good, reliable power with plenty (if you know where to look. SummitRacing has rebuild kits for the olds 350 for like 600$) then an Olds 350 or 403 (even more common than the 350) are the way to go. Plus, with the 350, you can use the heads and intake from an Olds 455 😀 It all depends on what you want to do. So, do you want a good reliable (again in stock/near stock form) motor, while still a V8, will never have the power capabilities of a 350, 403, 455 etc., or do you want to do a swap? If you got the time and $$$, it is a no brainer. But, it's your car. Do what you wish.
