Who uses the factory 14s
yennchi45
Nov 12, 2014
91
84
38
South Carolina
Who uses these? And what size tires look good on them?
I'm going to put some 14" factory Pontiac wheels on my Bonneville . I have 205-70 tires on them. They Have a little taller sidewall. Probably not an improvement on handling but I wanted to fill the wheel well a little more . Haven't put them on my car yet although I did have some 14" factory wheels on it before . Here is a couple of pics. timo22
You are limited on tire sizes with 14" rims. Here are 245/60R14 tires on factory aluminum rims
Here are 205/70R14 and 235/60R14
Reactions: UNGN
30 years ago, 14" wheels were on everything, now they are on virtually nothing. 235/60 is a good size if you can find tires. That is what size I had on my 'Cuda's and AMX's I drove. On my SC360 I had 205/70 Eagle GT's and it handled good but the short tire made its top speed 104 mph at redline.
I have derpy 14s as well, steels. 195/75/14 blackwall Primewells on the front. Need some new ones on the back. Good tires, cheap. Not that this is really a contest, or what the thread's about, I had my Regal upto what I believe was 130ish mph with 195s. Speedo was buried and I was at 4100rpm.
Larger rims are necessary for any decent brake upgrades. I am putting on 225/70R14 tires on the back to drop some rpms and make the speedo accurate. Here is the same tire combo that fit the G body well, almost looks small on my 70 Cutlass. I am considering 255/70R15's for the 70, they should fit the wheel wells are huge.
Reactions: Longroof79
will a 235/60/14 fit a factory 6 inch steel wheel ?
have 2 sets of 14 inch the gold set is original with 235 's on them and the front tires do rub on the inner fender well when I do a full turn on the wheel the the other set is off of a 85 cutlass and they are 225's no problems with them . Its very hard to get 14 inch tires in Canada BF goodrich is owned by Micheal and only do 1 run of 14 inch tires in the year so when they sell out wait til next year . If I want new tires I have to pay for them first and hope they do a production run early in the year good luck Jeff from Winnipeg
