when you are driving if you pull in on the door does it go away?you could always go and have a friend spray it with a powerwasher while you sit inside and look for leaks.These little problems can sometimes be a big pain in the *ss.ladodger said:Yeah, I replaced both the door seals and the roof rail seals. This is a summer car as well, but I still would like to eliminate the noise.
gwhiz said:when you are driving if you pull in on the door does it go away?you could always go and have a friend spray it with a powerwasher while you sit inside and look for leaks.These little problems can sometimes be a big pain in the *ss.ladodger said:Yeah, I replaced both the door seals and the roof rail seals. This is a summer car as well, but I still would like to eliminate the noise.
