Someone attempted to break into my 87 Monte Carlo hard top on the passenger side a few weeks ago. I returned to my car to find the passenger window pulled out passed the little clip on the outside, grease along the top of the window, dots of grease on the interior etc. Worst part is I left the drivers door unlocked.
Now the manual window does not properly roll up when the door is closed. When the door is opened it rolls up but the rear portion of the window does not go up as fast as the front, i.e. the top of the window does not stay level. This only occurs after the glass is half way up. When the front of the window reaches the top then it only takes a little movement of the crank to get the rear up if the door is open. If the door is closed it start to catch on the weather stripping and jams. I have looked inside the door and there are no adjustments that seem to help with this. How do I fix this.
