Wiper motor bad or what
dickeymoore
924
Atlanta,Georgia
I have a 1980 Monte Carlo and early in the mornings the wipers dont want to seem to work unless i pull up on the wiper arm, is this a case of a wiper motor going out or what but they work fine in theevenings after work?Thanks
12,176
9,795
The way you describe it, it sounds more like a problem with the switch itself.
12,176
9,795
Now, your car is an '80. Would your wiper switch be on the dash, unless it was converted to a column mounted switch.
It sounds like your wiper motor is functional, but getting bad contact somewhere.
tkruger
358
310
NY
Check that your linkage is free. I had a truck that the linkage was binding slightly on. They moved slowly until they got moving after a bit.
JimmyCamino
124
106
Alexandria, VA
These wipers are sensitive to being well grounded. Loosen and retighten the screws holding the motor unit to the firewall mounts. That might help.
