Wire/cable sizes
-83MONTESS-
4,570
967
Bellevue, Ohio
Can someone explain the difference between 1/0 and 0 gauge? When I relocated my battery to the trunk I used 0 gauge car audio cable. It really didn't seem thick at all but I figured 0 gauge was 0 gauge. Well after driving around for a while I realized my volts jumped back and forth from 12 to 14 on the gauge. When I got home I noticed that the ground cable from the battery to the frame was very hot. My buddy suggested going with some 1/0 welding cable and as I search I find 1/0, plain 0 gauge, and stuff that says 1/0-0 gauge on it. Whats the difference and what should I use?
I have my battery in the trunk and run a 4 gauge wire with no problems. BMW have used a 4 gauge wire from the battery in the trunk for decades. I ran a 8 gauge ground to the body and to the frame from the trunk. I grounded the engine from the frame to the engine and I grounded the body in the front from the frame. This is the 23 lbs battery I have in the trunk up on the ledge behind the back seat the company sells wiring kits that are 4 gauge.
So if 4 gauge is fine my 0 gauge car audio cable must be fine right? If thats the case then why would the ground cable be so hot? I also have an intermittent slow crank still. Seems like if I go to crank the starter it will crank very slow at first then speed up. Does it randomly no matter the temp of everything....
Technically 0 gauge and 1/0 are the same. Unless you are pushing some serious amps, your wire is plenty big enough. 0 gauge can handle up to 240amp load. When a wire gets hot it is either from excessive load, poor connections, corrosion. I would verify cable connections are clean and tight. Is the frame connection clean metal or painted and only ground is the bolt contact with the thin edge of the hole?
Just guessing here, but check your grounds, and check that you have enough of them. The 0 gauge audio wire is made for heavy loads. The only difference I can think of is a more flexible (softer) casing, which may be transferring more heat than the typical automotive wire, which seems to have a heavier casing.
