Do you have a clutch pedal stop? That would put the pedal height were it should be. Wouldn't pulling the pedal towards the firewall take away your throwout bearing gap?
Russ
My pedal is solid. No slop. By having the pedal retracted all the way back I can then adjust the free-play to what I want. I like a good 3/4 to 1" of free-play before I can detect contact. I use my hand to feel for this as my foot is not so sensitive. Then I like total clutch release long before the pedal gets near the floor. I hate a pedal that goes to the floor before the clutch is disengaged. No room for error. That is why I drilled a new hole in my Z-bar to re-locate the upper clutch push-rod. That changed the geometry just enough to get the pedal away from the floor. See the springs I use.I dont know how your pedal feels
My pedal is solid. No slop. By having the pedal retracted all the way back I can then adjust the free-play to what I want. I like a good 3/4 to 1" of free-play before I can detect contact. I use my hand to feel for this as my foot is not so sensitive. Then I like total clutch release long before the pedal gets near the floor. I hate a pedal that goes to the floor before the clutch is disengaged. No room for error. That is why I drilled a new hole in my Z-bar to re-locate the upper clutch push-rod. That changed the geometry just enough to get the pedal away from the floor. See the springs I use. View attachment 148231 View attachment 148232
Guy,
Here is a stock reply I have about clutch return spring.
The main thing you need the return spring to do, is pull the clutch pedal against the stop, and hold the fork and throwout bearing away from the pressure plate fingers.
Any spring that does that consistently will work.
When using one spring, pull from the fork toward the front of the vehicle. And make sure, the pedal is against the stop and the spring is stretched. The spring will stretch more when the pedal is stretched.
The reason you want the spring stretched with the pedal up, is so it won't jump off when the pedal slams the pedal stop.
Now without a pedal stop it is hard if not impossible to get a consistent clutch adjustment and have the pedal height correct. It is the starting point for clutch adjustment.
It doesn't take a fancy pedal stop on these cars. Just a flat piece of steel attached to the hanger bracket.
Russ
Russ
Guy,
Russ
That is how it is "supposed" to work. Old cars had the spring at the pedal and assumed that when the pedal came back, all the linkage followed and the TOB was not touching the PP fingers. But remember that old cars had a huge amount of room under the dash and the pedal travel was so great that pulling the pedal back was all you needed. If you ever drove a 50's car pushing the clutch pedal was hard on your leg and it felt like the travel was measured in feet. Now we have our era cars where there is minimal amount of room and pedal travel is restricted. So all the slop in the system adds up and the pedal coming all the way up may not be enough to get the TOB clear. Don't forget the geometry at play. An inch of pedal travel equals only a fraction of an inch at the TOB. It is that way to get the mechanical advantage to compress the PP springs without needing a gorilla leg to push the clutch pedal. That is why even the factory used a return spring at the clutch fork to make sure the TOB was not touching. I just took it a step further.the spring I had on the clutch pedal was just enough to take up the TOB clearance
