From there website
http://www.optimabatteries.com/optima_p ... /index.php
Demand More from Your Vehicle?
The
YellowTop® high-performance AGM battery is one of the only true dual-purpose automotive batteries available. With premium cranking power and unparalleled cycling capability (rechargeability), it is perfect for modern accessory-loaded vehicles. The
YellowTop can repeatedly bounce back from deep power drains to full energy capacity, so it can power plenty of electronics and still start you up time after time. Lower internal resistance also provides more consistent power output and faster recharges.
Trucks with winches, vehicles with multiple electronics, cars with high-demand audio systems, commercial vehicles and heavy equipment all rely on this battery to provide ultimate starting and deep cycle power.
Gentlemen, Start Your Engines.
The
OPTIMA® RedTop® high-performance AGM battery is the ultimate high-CCA starting battery designed to deliver the strongest 5-second ignition power for a reliable start-up every time. The RedTop will outperform and outlast traditional batteries in demanding cranking/starting applications. With unparalleled high power delivery and extreme resistance to the most common causes of battery failure, the RedTop is idea for trucks, SUV's, luxury cars, hot rods, off-road vehicles and other applications that require a leak-proof starting-only battery.
Endurance an Issue?
Installing an
OPTIMA® BlueTop® high-performance AGM battery in your boat or RV means more running time and up to 3 times more recharges than what you’d get out of a traditional battery. It’s perfect for boats with electric trolling motors, onboard electronics or stereo systems and RV's with “creature comforts” that tend to drain batteries quickly. In addition to providing weight savings and outstanding vibration resistance, the BlueTop’s efficient power delivery and faster recharge time mean you’ll spend less time worrying about your battery. The OPTIMA BlueTop is ideal for those who need a sure-starting, strong cranking, maintenance-free power source.
