The Dodge Stratus/Plymouth Breeze fans also fit and cool very well. I am running them and have had nothing but issues with controllers and relays. A toggle switch with good heavy wire and a 30 amp fuse inline is the way to go.
If you are wiring the relays correctly and still having issues I am thinking either they are really low quality or you are putting more of a load on them than they are rated for, it never hurts to give yourself a safe margin above what you need especially with electric fans that have a very high amp draw at start up.I am running them and have had nothing but issues with controllers and relays
Yup, had to look that one up, glow plug relay and it does look like a starter solenoid.I am running a Taurus fan on high with a $20 controller and a glow plug relay (looks like a starter solenoid but rated for continuous power).
I have had thermal switches die, adjustable controllers adjust themselves, usually turn on at 250 degrees and multiple relays die. Always somewhere like the track where you really need it. I couldn't stomach nearly $200 for a GOOD controller, anything decent for reasonable? I was tired of making a 1/8 mile pass then looking at my temp gauge going critical.
