i got my car running, kept the stock 2004r and swapped the rear end for a 373. drove it around the block and it seems to take a min to shift either 1 to 2 or 2 to 3, and when i slow down to come to a stop it almost acts like a stick shift, now the 3 wires coming up from the trans are still connected to the computer, i did an engine swap so none of the old harnesses going to any of the emmissions crap was used, so from what i can tell those are the only wires that are connected from the big loom underneith the hood, i have no heater box so i can trace wires if needed, its an 87 limited, so another question is can the computer work for the trans without having anything else hooked up? i know its got power i just want to eliminate the wire loom, to clean it up a lil and with out having to buy a kit for the torque converter which i yet to understand how they work.. also does my trans have a vaccume line going to it that i would need to connect it to somethig if it does.. also it shifted fine before the engine swap so its only been sitting for a year..thanks
