81 Olds Cutlass 3.8/350c to 72 Buick 350 & complete resto
tobyp
1,708
44
48
Cincinnati, Ohio
I started the project about three months ago and decided to use the Buick swap for the simplicity sake of the swap
Re: 81 Olds Cutlass 3.8/350c to 72 Buick 350 & complete rest
The engine prior to dissasembly
building the engine
Nice to see another Buick swap in progress. I always like to see the BOP projects.
Cross Member install and trans
Interior restorations
fMore interior restoration and complete teardown of Moon Roof
Bumpers, Exterior, etc
New rear bumper replacement
Great work and you are moving right along on this project. Kudos! Consider a four barrel Q-jet and lightweight aluminum intake will give you both better mileage and more power and can come with a nice electric choke for the winter. I linked one at TA Performance but other Buick vendors may have it cheaper or someone may be selling it used on the Buick boards. Also spend a few more bucks and get a much better cam & kit if you were considering putting a stocker back in. Not at all wild or unreliable just much better than original. Maybe close to 300HP & more torque with these upgrades and great driveability mileage etc. Just an enjoyable ride that you will take pride in and be real pleased with how nice and strong it runs. Double Kudos on employing daughter helpers!
http://www.taperformance.com/products.asp?cat=101
http://www.lunatipower.com/Product.aspx?id=2400&gid=297
Edit I hope I wasn't insulting as I can see you are more than competent. Just trying to throw some things out that may be worthy of consideration.
