Looking into some electric fuel pumps to feed my 670 Holley carb. (5.3 engine with around 400hp) Wondering what you guys have used or recommend, and where to attach it to? I just removed a device of some sort, looks like an air shock suspension leveling thing (actually, I need to ask about what to do with that too) and I wondered if I should just bolt the fuel pump in it's place. But I read that you want the pump positioned below the gas level in the tank.
Also, do I need to worry about GPH? 60, 90..?
I'll probably run a separate regulator and a return line
Thanks
Thanks
