rustyroger said:
bigt0006 said:
thanks for all the info. my car has the 200 metric transmission not the 200r4
Behind a big block you might compare it with bringing a knife to a gun fight
Roger.
The 200 on a '87? That sucks. That's not even a knife to a gun fight, it's more like throwing rocks in a gun fight.
The only trans that will bolt directly in place of a TH200 is the TH350. And the hard part about that not rebuilding the 350 to handle the 455s power, it can very well. Finding the BOP TH350 is a super challenge. Especially the lock up version.
Your only real choices are the TH400 and the TH200R4. As stated before, the 400 is cheaper to build but, adding the cost of the custom driveshaft will bring it up to the cost of building the 200R4, which uses your current driveshaft. Which can hold more power is arguable. The 400 will be the popular choice, But there are 200R4s that can handle up to 1000 hp. Mega expensive.
IMHO, I'd start looking for a BOP 350 or the Cross pattern BOPC 350. You may get lucky.
Side note, Don't even think of using a adapter plate on a 455, it WILL flex and break the bell housing.
T
