I figured I'd post this for anyone wanting to swap a factory tach into their existing Pontiac cluster. I originally planned on swapping the entire cluster but the printed circuit was damaged.
To see if it would work I removed my original cluster from my '78 and compared it to the damaged one with the tach. My original only had a speedometer and a blank silver plate where there's normally a clock. Other than one additional circuit to the speedometer, the printed circuits were identical.
I won't go into details about removing the clear cover, tach or speedo. It's only a few bolts and almost self-explanatory.
Pic of damaged circuit (broken copper strip where the connector goes)
The cluster on the left is the one from my car. The one on the right is the one with the tach. Notice the silver clips on one with the tach. These clips make the connection between the studs on the tach's circuit board to the printed circuit on the cluster. I removed the "center/top" one and placed it on the table. My original already had one clip installed at the "center/top" position.
After pulling out all the clips you can see the contact marks on the copper strips. Use a decent set of needle nose pliers and take your time to remove them from the inside. Back one end out at a time and they should pop out. If you try forcing them you'll most likely bend them pretty bad or damage the plastic on the cluster.
After taking the two retaining bolts out of the tach (12 and 6 o'clock), the tach can simply be pulled out. Here's the inside of the donor cluster before removing the remaining clips that connect to the tach's circuit board pins.
Here's my original cluster with the clips installed. Notice that this printed board is much nicer than the one from the cluster that orinially had the tach. All there is left to do is install the speedo. It's also a good time to check the bulbs for broken filaments and change them while it's out.
